SH847 (in Europe?) Suppliers
Was just checking if it was a Lithium. I have suddenly started having similar issues to yours on my old Guzzi.
If I were you I would test the continuity of the STATOR windings - as that voltage sounds VERY low to me - If the rect/reg swap makes no difference and you are content with the battery then I would worry.
Can you borrow another battery to test with?. Sometimes batteries just die.
The stator looks to be cactus.
The continuity test is showing 0 or short circuit.
At what resistance are you measuring? The resistance is going to be 1 or 2 ohms at a guess. If the multimeter scale is too high then it will read as 0.
Think about it - basically the stator is just a long wire wrapped around something - There is VERY little resistance at all. High resistance would be BAD.
But too little would be bad - A true short.
Let's call @DEcosse
I’m using an old Fluke 77 digital multimeter.
The attached show readings of .5, .4, & .3 respectively across the three terminals.
Thanks Tony
Im happy for the upgrade but I used one of the engine mounts to test for stator continuity so lm thinking the battery earth would not have been a factor.
