possible ignition switch?
I didn't get a chance yet to get the part # but better still I had a request from a Roadster owner to make him one so I will make one take lots of pictures along the way including the installation on the bike, ..... so stay tuned
Not only will the EB mod save your new (or repaired) ignition switch it will make your headlights MUCH brighter. Here is mine before and after EB mod.
Holy, "Let there be LIGHT!"
That IS indeed an incredibly dramatic difference!!!
yeah it is more noticeable on the bikes that are about to have an ignition problem!!!! I had very little difference with mine as the bike was still very new when I did mine
Well $hit, there you go again!
Explaining something to me that hadn't made sense before.
When I did the beaver (wiring that is) my motor was pretty new and I didn't really see a noticeable difference.
Thanks, Mate!
Thanks, Mate!
Scary is it not when someone so far away can read you mind ...... no dont do it .... leave it alone
BTW - as you likely know, I recently installed a set of Daymakers which are somewhat different than the JW Speakers.
Now that I have found a flat open large place with non measureable ambient light and purchased a high quality NIST light meter, I intend to do some serious light testing soon.
I am interested in checking out what you say about the LED beam pattern and shall publish the results here for anyone interested. My plans are to establish a data base of motor lighting to be incorporated into a colleague's (PhD in human factors) research papers and computer program.
trouble shooting tree
questions
MODIFIED ON 5/12/14
#1 when you turn the key on does the needles sweep and the headlights come on yes go to # 2
or no could be battery,ignition switch,fuses,connectors under the tank,engine management relay,ect
#2 does the green light come on for neutral yes go to #3
or no could be not in neutral, bad gear sensor,wiring
#3 with the clutch lever pulled in push starter button does the engine turn over yes go to #4
or no could be bad starter button, bad kick stand or not all the way up, bad starter relay, bad battery or bad connections at battery,
#4 the engine is turning over good does the motor start yes your are ok till problem shows up.
or no. Can you hear the fuel running for about 2 seconds as soon as you turn the key on yes go to #5
or no could be bad fuel pump, fuel pump relay,wiring
#5 assuming the fuel pump has enough pressure the problem could be terminals at coils,bad gas,injector or injector wiring.
we have seen connectors,fuse terminals, the wire on ign. switch melting,
this is just a helping hand and does not cover all problems. there may be mistakes in this as i have not spent a lot of time typing this. i may make changes latter and welcome info from hanso, warp and others to correct the info i have typed here.
hope this helps herman
i have been a mechanic for 50 years. the last 39 years i have had my own automatic transmission business and worked on vehicles with many types of electrical problems,like ign. switches, computer problems, shorts, failed relays, and vehicles worked on by other mechanics, ect.
over a period of time the ignition switch gets bad because of the arching when you first turn it on. when your bike is new everything works great and the current to the lights is good. after your bike (and your ign switch) gets some miles on it the ign. switch will no longer flow enough current through the contacts. this causes access heat and can melt the main white wire off the switch, also can cause the connector under the tank to go bad.
many people has installed the eastern beaver or relays to correct this situation, which is very good advice. however you still have the ign. switch with bad contacts that is feeding the starter. some people (like me) has also taken the starter solenoid out of this circuit and have had no problem with the ign. switch.
in the older rockets the power comes from battery through fuse #11 through fuse #2 then by white wire to ign. switch through fuse #9 through the starter relay to headlights.
the best way to check is while you are having the problem is to check voltage from ground to fuse #9 if it is less than 8 volts you need to replace ign. switch. if you are short on money you could possibly get by and do eastern beaver(or relay mods) and take the starter solenoid out of the circuit(starter relay mod)
when i first came to this site i knew very little about the rocket my knowledge was gained through the problems posted and a lot of good guys taking there time to try and help us with our problems. i would like thank those of you that welcome newbies and spend time helping us with our problems.
herman
