Do I need keyless ignition and a headlight relay kit on a '14 Roadster?
JudgeMontrose
North Carolina, USA
'07 Speed Triple, '14 Rocket III Roadster
Hey all,
I have a '14 Roadster, which I ride in all weather. Should I get the Eastern Beaver headlight relay kit and a some sort of ignition upgrade, or were those issues solved by my model year?
Dawg68
Nitrous
Chilliwack B.C.
2014 R3R / 2017 R3T
I also have a 14 Roadster. That I use as a commuter on a daily basis in all weather. I have had no issues with the ignition. I don’t believe the relay kit is required on the 14 and newer. I even have powered assessories installed but I used a proper power distribution block to avoid drawing power off of the ignition and headlamp circuit.
barbagris
Mad Scientist
On the verge of insanity
2009 R3 - 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Hey all,
NEED? - well no. The question is do you WANT keyless. If so - speak to member @DEcosse. A prince amongst electrical gods.
idk
Maryland
BMW R1200C
If you want an inexpensive keyless ignition, then look at my signature and make your own. Ken's system is much easier to install, and technically better though.
DEcosse
If it's no Scottish it's CRAP!
Bay Area, CA
Triumph Daytona (Custom)
No, you don't 'need' either - there are no reliability issues on a '14 Roadster
KeyLess system is just going to be purely for its own merits of convenience and coolness! :p
It does have some security advantages - you can't stick a screwdriver in it to hot-wire it, like you can a key-switch :D
DodahMan
Turbocharged
Coastal South Carolina
Yamaha Roadstar, 2011 Triumph Rocket III Tour
I would like to know more. I am fairly new to the R3T and still evaluating what I would like to have done next. Mine is a 2011. If there is a concern, What would you suggest for the ignition? Thanks.
