neville lush performance kit
albertaduke
former airline pilot without the big bucks
kaleden
2021 rocket3 GT
today I am ordering Neville lush performance kit it will comprise pistons 3 of them I hope two high duration camshafts with slotted gears for best performance I already received the cam chain tensioner from NL . rather excited to get the stuff and get it installed .
some knowledgeable captains have explained to me the easy way into the motor I will pass on this info to the wrench ,I have the parts from triumph on order as well head gasket ( that one is not cheap) head cylinder bolts, big end bearings, bolts , and cover gasket expect after a good tuning from nels byesdordf to see hopefully 200hp and a somewhere around 180lbs of foot torque or better . to do justice to this setup I will take the beast to the maritime provinces for a summer trip of a lifetime and return by way of boston ,spearfish cody etc etc see you guys this summer..
You're going to have a real beast on your hands when this project is done, duke.
Approximately what is the cost of all of those parts you mentioned?
nev stuff two grand triumph stuff $500 barnett clutch spring $15 labor around $1500 all canadian and aussie bucks
I like the idea of getting lots of grunt at low RPM I just don't rev my machine up in the nether region so Nev stuff is right up my alley
Sounds like the same setup as I have, 201rwhp with the Exceedra Max on
AAHHH!! I guess you are happy with the results!! on the sucking side ramair on the spewing side jardine on the rolling side exedra max in the rear and avon azaro in the front... is that what you also have??
My front tyre is the 140 Michelin Commander which is worn on the rhs but overall it has been good for handling, after reading various threads and communicating with TriumphPhil I will be trying the 130 Exceedra up front next. I have a classic so clearance and ABS is not an issue.
well in any case enjoy!!!the results,,
