Minor clutch adjustment
Hopefully you can see the shifter in this pic. Just the stock non-adjustable shifter. I thought about a 'thinner' shift lever too actually. The New Bonneville website has a set but it'll cost me about $180. Where did you get those levers Mittzy?
Also just a quick side question. Can you run bias ply tires on the R3T? Or is the bike designed with radials in mind?
Ok now were getting some where are those OEM on the touring I ask as I have the Classics and standard which have adjustable levers? Next can you take a picture of the other end of the cable down where it fits into the mount on the clutch cover. I am especially interested in the two nuts on the sheath and the threads on the sheath.
I'm Mowing my neighbors lawn I will check back on UNION break :D
Yes that is the lever the bike came with. I'm at work right now, on the road, but will snap a pic of the other end when i get back to the shop.
Union break for the win.
$30 from eBay , not sure about the tyres
THOSE shorty levers are not comfy with less leverage and thin blades the latest ROCKET levers have wider blades and more leverage and are adjustable and are the best for comfort and leverage if you have stronger clutch springs I have 2 sets of those shorty levers we took off bikes that came in for engine mods
Your opinion only. I don't ride purely for comfort, I have big strong hangs and heavy clutch springs with no troubles at all pulling the clutch. I took my fat Roadster levers off after the bike had a soft tip over and clutch leaver broke as those fat levers have no break point grove they will break at the top - the weekest point.
Going back to an earlier post, the locknut against the lever, it should be as that is how it locks. Loosen it off, make your adjustment then retighten. Hope I'm note stating the bloomin obvious.
Ok, here are a couple of pics of the other end of the cable. I can always remove that mesh cover for a better pic.
I am interested tho in maybe replacing the clutch lever with an adjustable one. I'll have to scour amazon and ebay.
Thanks @Fingers for the tire feedback. Its good to know there are a few tire options.
ok so it look pretty close to both my bikes. I find it hard to believe Triumph did not put adjustable levers on the beast. I will be even more surprised when I start paying more attention to see if it has always been that way or if it was a change.
THOSE shorty levers are your choice and the average rider is not going to find them user friendly they make it harder to pull the clutch in and they have narrow blades that arent as comfy as the adjustable wide blade TRIUMPH levers
