PaddyO
Finished installing MC Cruise control on 2014 R3T this evening. Started the bike up and the throttle was way high. I had backed out the "Carburetor Cable" way out of the CIU in order to adjust the freeplay in the throttle without having to screw the throttle adjuster almost all the way out when adjusting the freeplay in the throttle. Obviously, that did not work.
Screwed in the Carburetor Cable until the idle came down to what sounds like normal. However, doing this meant backing out the throttle adjusters on the grip almost all the way out for the two cables that go into the throttle.
Is this normal? Is there another way to adjust the freeplay in the throttle without messing up the idle?
Thanks in advance for any help.
