Some people just can't fathom forward control.....some like I can't see a riding position that you can't maintain comfortably for twelve hours....so forward it is for me.
Raask rearsets cater for a wide range of motorcycles that go as far back as the late sixties and go right up to the modern day, if you can't find rearsets anywhere else for your bike then chances are that Raask can do it.
These classic style rearsets come with epoxy painted alloy mounting plates and are equipped with brass bearings and rose jointed links, they are supplied with fittings and mounting bolts where required.
- especially stable
- durable
- custom-fit
- easy to install
The simple, simple and factual design have made them one of the most widely distributed footrest systems ever.
I have a set of custom adapted Italian Rizoma PE112B FZ1 '06-'15 Yamaha ones that the infamous and now sadly deceased blastedbones had on his Carpenterised R3.
They have CNC alloy billet adapters with castellated fittings to match the R3 frame and rear Brembo brake hose/piston/cylinder/bracket, carbonfiber heel guards, folding peg adapters PE-606A etc. They have a couple of tiny scuffs on one of the CNC billet adapters I plan to polish smooth but the mechanical linkages etc are perfect and I bought a replacement set of Rizoma B-PRO PE616A pegs and a brake toepeg PE624A for them so they will look as new.
These Rizoma sets are now discontinued and it must have cost a fortune to get the adaptors machined up. I just like looking at them and admiring the engineering and finish.
If your left hand peg is ground back the same as your right the pegrail up the front on the left will have a hole worn in it. If you keep pushing harder the next thing to scrape is the end of the handlebar. Don't ask me how I know this, I just do.
