Dobeck used my bike to determine the best AFR settings and develope the program to control the injectors. It works great as is. No worries the AFR settings will be right. Pesronal tweeking of the AFR and switch points is done right on the AFR gauge. Very simple to do. The adjustments for the switch points are also simple and you set them to where you like them. The best way to understand it is to buy it. Call Dillon at Dobeck and tell him I sent you. As a forum member you get a discount, and if you are current or veteran military there is a bigger discount.
Bill
