DIY - Valve check/adjust; timing; clutch change; fuel and air filter; spark plug change maintenance....
Great post - did the valve timing on my Tiger 900 RP- and plan to do everything on this also.
2021 - only 7k on the clock - but thinking of doing the 10k service.
I have changed the oil - that's about it. it will be another 12months if I wait for 10k.
Gearbox Oil / Diff
Oil & Filter
Lube drive shaft
Clutch Fluid (but this is the pan part - radiator..) correct big job...
Radiator flush
spark plugs
Air filter (is an after market - Hi flo worth the money)?
Brake flush
thoughts?
Thanks. I also wrote up something on the 10K (see below). That and the 20k video together might be helpful.
Lube the Splines
Yeah, fully flushing the clutch fluid gets into the 20K service, but if you suck out the MC and replace that, it'll be pretty clean after successive changes over time. Be careful not to suck out too much and, in any case, you'll want to bleed the MC. The procedure isn't mentioned in the manual, but it's the exact same as for the front brake, which is in the manual.
I have stayed with stock air filters. I was convinced long ago that more air in also means more dirt in, which intuitively makes sense to me. This may be a hot topic. If I change exhaust at some point I may decide to go to hi-flo filters then. 🤷🏼‍♂️.
3K in a year? You gotta work on that ;-). Good luck and keep us posted on your progress.
