Got the same Chinese bulbs but set mine up as they were intended?? Wired the amber bulb wires to the turn signal hot wires (each side to the respective turn signal). Wired the white halo ring wires to the parking light bulb wire. Wired the low/high/ground as expected but added an on/off switch to the low beam. Now I have high/low beam lights with integrated turn signal (amber halo) around the light for night driving. I have daytime running lights (white halo) without low/high beam for daytime driving (daytime running lights turn off automatically when the turn signals are activated and come back on when signal lights are turned off), and have white halo for parking lights. Pretty cool, just like the newer cars you see on the road! Another plus of this setup is the significant load reduction on the ignition switch when running during night and even more during the daytime. Also, if you have a table sander you can easily sand out the inside of the OEM retention metal ring to match the bulbs and fit perfectly into the housing (just like the original bulbs).
