Damaged crankcase with pictures
Discussion in 'Common Issues' started by PaddyO, Jul 12, 2019.
  1. PaddyO
    PaddyO Supercharged
    Country:
    United States
    371
    Featured Threads:
    5
    Media:
    7
    383
    73
    Salt Lake City, Utah
    Ride:
    2014 R3T
    While transporting my R3T in a moving truck, the kickstand was left down without my knowledge when it was strapped in. At the first stop, I checked to make sure the straps were still tight and discovered the kickstand was down. I reset the straps with the stand up. However, when it came out of the truck, it appeared the kickstand bracket had broken and the bike was leaning way over. Tonight I was going to replace the bracket and discovered it was not the bracket that was broken, but where the bolts attach to the crankcase that had broken. Pictures below.
    IMG_2648.jpg IMG_2649.jpg IMG_2650.jpg IMG_2651.jpg IMG_2653.jpg IMG_2654.jpg
    The last two pictures show each piece held in place by the bolt.
    I am wondering if I used JB Weld epoxy to attach the pieces to the crankcase if it would work? I am thinking of wrapping the bolts with teflon tape so the epoxy won't attach to the bolts and after the epoxy sets, I would then be able to back out the bolts. I might have to use some washers between the heads of the bolts and the crankcase pieces to press the pieces against the crankcase. After the epoxy sets, I could apply some more epoxy around the outside of the pieces to further attach them to the crankcase.
    What do you more knowledgable members think? Any other suggestions?
    Starmanut and Joesmoe like this.
  2. Danvitt
    Danvitt .060 Over
    Country:
    United States
    102
    Featured Threads:
    6
    157
    53
    Richmond, Indiana
    Ride:
    2013 Roadster
    JB welds pretty good stuff, I don't see why it wouldn't work. If it were me I'd probably get it to set without the bolts and just run a tap through after it hardens. The teflon may work though. Doesn't hurt to try.
  3. barbagris
    barbagris Mad Scientist
    12,096
    Featured Threads:
    57
    Media:
    85
    12,543
    823
    On the verge of insanity
    Ride:
    2009 R3-Standard - 1979 Guzzi V1000G5
    OK - I would look for an Ali-welder. I seriously doubt epoxy is going to hold that WELL.
    Then retap and maybe even fit inserts.
    And when it comes to refiting - DO NOT USE BOLTS. Find a stud and run it all the way down the thread. Use nuts to than pull the bracket against the engine.
    TURBO200R4, Dawg68, BigNorm and 11 others like this.
  4. PaddyO
    PaddyO Supercharged
    Country:
    United States
    371
    Featured Threads:
    5
    Media:
    7
    383
    73
    Ride:
    2014 R3T
    What is an all-welder?
    The studs/inserts/nuts makes sense.
    Nat67 likes this.
  5. Joesmoe
    Joesmoe IMOKUR2 Staff Member
    Country:
    United States
    4,300
    Featured Threads:
    47
    Media:
    7
    5,835
    823
    Fairfax, Virginia
    Ride:
    Triumph: 2014 Rocket III Touring
    Not "all-welder" -- rather "ali (that's an 'I') - for aluminum. The proper term in the US is brazing.
    Good luck, and let us know how it works.
    That's a bummer of a birthmark Hal.
    I sure hope the mover's insurance reimbursed you.
  6. Scorp
    Scorp Adrian
    Country:
    Australia
    740
    Media:
    7
    643
    103
    Perth Western Australia
    Ride:
    Rocket III Classic 2006
    I had similar issue with my RHS running board fixings after accident. You will find you can tap in a longer thread and use a longer bolt. Still do the epoxy for cosmetic purposes.
  7. 1olbull
    1olbull Riding Motor Since 1950
    Country:
    United States
    21,932
    Featured Threads:
    113
    Media:
    5
    19,381
    823
    Tacoma, WA
    Ride:
    2012 R3R "Kong" - 2011 R3R "YurMama"
    heliarc
    BigNorm likes this.
  8. sonny
    sonny Living Legend
    7,080
    Featured Threads:
    121
    12,847
    823
    Henryetta Oklahoma
    Ride:
    rocket three x
    I am a very experienced welder. Just looking at the cast would be enough to make me run the other way. Not saying it could not be Tig welded but chances are you would not have much luck. Grain of cast is very rough.:(:(:(:(:(:(
    kipper, Bedifferent, Nat67 and 8 others like this.
  9. barbagris
    12,096
    Featured Threads:
    57
    Media:
    85
    12,543
    823
    Ride:
    I'd be making sure they made good.
  10. scot in exile
    scot in exile Living Legend
    Country:
    United States
    8,648
    Featured Threads:
    201
    11,541
    823
    Fort walton Beach FL, Glenrothes Fife
    Ride:
    2005std, 2011 Carp Roadster, 2001 Tri Adventurer,
    reading the first post it seems like he was the mover, can you sue yourself??????????????
    BigNorm likes this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
