Mongler07
As some of you know i did a 1.4kw starter swap
I also just changed out my battery to a new one as the old one was on its last legs and left me having to do a few push starts...
NOW i have a unusual problem i have no idea whats going on but i assume its some relay or ECU issue?
When i Go to start her up, regardless of how long it has been since it ran last from 5 seconds ago, to last night, if i cycle the ignition it WILL NOT START unless i try a 2nd time pushing the starter button. The cranking speed is slower and no matter what you do it WILL NOT do anything but just crank. When i stop and hit the starter bottom again for a 2nd time, it cranks a LOT faster and starts immediately. EVERY TIME.
what did i do wrong? all i did was change a battery and a starter. Everything is hooked up correctly, runs great.
Its like the ECU is not firing the injectors or something but I'm not sure as its also a slower speed its cranking at on the 1st attempt.
it did NOT do this with the new starter but only when i swapped the battery. BTW it never did this on the old battery even after a few bump start events. The new battery is healthy 12.89v after an over night sit and was tested at battery plus and has its full 310 CCA
