Terryfyd
I purchased a 2005 Rocket III several years ago. One of the first modifications I did was put in a Barnett Heavy Duty Clutch. Over the years I've had to continually adjust the clutch cable tighter. Several times I even had to re-index the clutch lifter arm on the clutch lifter shaft as I ran out of cable. Today I bit the bullet and cracked its chest open again. The problem was apparent immediately. The lifter piece wore through the lifter shaft where they make contact. I'll be ordering all new pieces that were affected. Are the Barnett clutch springs too strong? Should I put my old springs back in? Could I have screwed something up on the install and still get 3 years out of it? Check out the pics. I had to grind down the lifter shaft to get it out of the clutch cover. any insight would be appreciated as don't want to make a habit of opening this thing up. Thanks in advance!
