clutch is dragging on 2016 rocket3 roadster
hoopla
Mained to ride!
Maine, USA
2016 Rocket Roadster
what I mean by dragging is when the clutch is fully pulled in, I can't get the bike into neutral, only when I turn the bike off, then I can get the bike into neutral.
When sitting at a light in first gear, I can not roll the bike back at all., my guessing is that the clutch is dragging, shifting is ok most of the time, some hard down shifts.
The clutch also has a shorter pull to the bar.
Do I just replace the clutch plates?
thanks
Hoopla
wjb
Nitrous
California Central Coast
2008 Rocket III Touring
Well, I'll ask the obvious. Is the clutch cable adjusted correctly?
The stock clutch is pretty stout, even tho it has to harness all that power and torque. They do wear out but they can handle a lot of abuse before needing replacement.
The adjustment of the cable is a little finicky, once adjusted correctly tho it works well. Start with the proper adjustment first. Hope that helps.
hoopla
Mained to ride!
Maine, USA
I believe it is, 2-3 mm at the handle
cootertwo
Top Fuel
Labelle Florida USA
2013, & 2 05's R3R, 2006, 2004 Harley's, 2004 Kaw
Well, if you do have free play at the lever, and the cable isn't binding, you probably have something going on "inside". It is a simple, but sorta complex design. Some parts are known to wear/break. Research! Lot's of info on this wonderful site, and people who have experience.:)
hoopla
Mained to ride!
Maine, USA
thanks!
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
Mine barley works on the orignal lever set at best setting.
i was wondering about those little levers not enough travel aparrenly not enough.
wjb
Nitrous
Your profile indicates that you have a 2016 Rocket which means that it came with the updated ball bearing clutch pressure plate and updated/strengthened lifter piece. At this point it looks to me like you will need to remove the engine's front cover and inspect and measure the clutch for wear.
hoopla
Mained to ride!
Maine, USA
thanks, I think that is what I will do.
Journeyman28778
Old Fort, NC 28762 USA
2020 3R , '11 Rocket III Roadster
It's not a terribly difficult job, in case you've never done it. The hardest part is removing and draining the radiator.
But, it is a bit time consuming. If it were me, and it does sound like the clutch is worn, I'd order a Barnett Clutch and go ahead and put it in there while you're already in there.
Btw, @warp9.9 gave me the tip on how to avoid also draining the oil- just tip the bike back a bit with jack stands to minimize oil loss- worked great!
Here are the parts for the Roadster you'll need....
Coolant
O Ring T3600910 $1.28
2011 Triumph Rocket III CLASSIC & ROADSTER O ring. System, cooling - T3600910 | HERMYS TRIUMPH eSTORE, Port Clinton PA
Water Pump gasket T3600169 $4.01
Clutch Cover Gasket T1260107 $12
2011 Triumph Rocket III CLASSIC & ROADSTER Gasket, Clutch Cover. Engine, Covers - T1260107 | HERMYS TRIUMPH eSTORE, Port Clinton PA
Barnett Clutch $238
Part# 303-75-20003
Amazon.com: Barnett - 303-75-20003 - Complete Clutch Kit : Automotive
