When I lift the tank of my R3T, I take out the 3 bolts which hold the console on (5 mm hex head), move the console to the right or left and unscrew the visible bolt. I replaced the torx head bolts with 5 mm hex head bolts. Move the console to the other side and remove the other bolt. I leave the console connected to connector. I then remove the 8 mm bolt holding the bear claw on and pull it forward to remove it. Slide the console down on the tank enough to clear the ignition switch, lift the tank from the brake side, take the rod under the brake side of the tank, place one end in one of the holes for the bolts which hold the tank down, and place the rubber end of the rod into the hole through which the bolts go. Slide the console into it’s normal position on the tank and it will stay there just fine. Be careful of the rubber gasket on the bottom of the console. If it come off, it can be a pain to get lined up and back on. Reverse process when finished.
