Bedifferent
Old man on a bike
I'm home now, so I am going to make one last post. It probably is overkill and I may be criticized for it being over the top, but here it goes.
Roadster and Classic Wiring
This may be beyond your skill set but prove useful at a later date
On your bike, fuses 1,2,3,4,6 and 7 should always show 12 volts across them even with the switch off. They are tied directly to the main 30 amp (fuse 11) coming from the battery. Fuse 2 is the main fuse that feeds the ignition switch while fuse 11 represents the main fuse tied directly to the battery and providing power from the battery to the fuse box. Fuse 11 is also tied directly to the rectifier and alternator charging system.
Fuses 5 and 9 are energized when the switch is turned on. Fuse 8 is also energized by a link connected to fuse 9. The critical fuses related to the switch are fuses 2, 5, and 9. Jumping between the these three fuses, in essence, bypasses the switch and would act the same as turning on the ignition switch. Fuse 10 also becomes active with the switch turned on, but it should not affect the ability of the bike to start... just lighting. As a final note, on my touring fuse panel, the outside edges of the fuses represent the powered side of the fuses and the inner terminals of the fuses in the center of the fuse box represent power THROUGH the fuse to the circuits. To maintain the integrity of the circuit being properly protected and fused, any jumping of fuses 2, 5, and 9 should be done on the inner most terminals of the fuses to avoid defeating the fuses and burning up your wiring.
To test the integrity of your switch, should you ever need too, I would jumper 2, 5 and 9 together with adequate gage wire and try to start the bike. The best way to do this would be to make pigtail fuses and put them in circuit with a 30 amp toggle switch. One terminal of the toggle switch being connected to the fuse 2 pigtail and fuse 5 & 9 pigtails being tied together and attached to the other terminal of the toggle switch. Flipping the switch would be like turning on the key.
