Emmoth
- Joined
- Apr 28, 2021
- Messages
- 42
- Ride
- Rocket 3 Roadster supercharged
Okej guys, I know the starter questions are quite common, but I have some issues!
First up I had an oil leak where the oil came from the evac channels behind the dry sump, which I was able to sort out by noticing that the valve cover gasket was not in place after I changed the camchain and valve adjustment, but now I have problems getting the bike started, the starter engages for like a second and then cuts out, and the starter sounds weak, not the distinct sound it used to make
I have a brand new lithium battery with 600 start amps
I have checked the relay and made the relay mod,
And last night i took apart the starter, cleaned everything and tried it when of and it had a good kick!
Is it supposed to pour out oil when taking away the starter motor? Like half a liter, or is this my problem caused by the leakage from the vc gasket?
