There a lot of decent O2 setups out there, the best reasonably priced one imo is the innovative LC-3. It can feed it’s data into the Innovative ecosystem of devices to enable datalogging of OBD data as well as the O2 data. I did just that for a while using the innovative LM-2, it’s nice because you can collect the manifold pressure data, so it lets you tune the L-Tables.
BUT, you have to do all your fueling adjustments in TuneECU, which, has it’s limitations and once you hit 180 WHP or so, it isn’t the easiest software to use.
Instead for a turbo setup I strongly advocated or the following, all from dynojet:
PC-V
PC-V Ignition module
Auto tune
POD-300
Multifunction Hub
Map Switch
3 BAR sensor
The PC-V should be connected to the optional inputs including:
Coolant Temp
Vehicle Speed
Then software wise, set the map switch to act as a pump/race fuel selector for two different maps. You can wire it to simultaneously close a relay raising the boost on an electronic boost controller.
Do not use “by gear fueling”. Use the Fuelig mode that uses RPM on one axis and manifold pressure on the other axis.
Set the ignition module to retard timing by 2 degrees per psi of boost and 1 degree per psi on race gas. Leave the ignition table all zeros.
Leave the autotune AFR targets all zeros while dynoing, then adjust the table to be MAP vs RPM instead of TPS vs RPM as it defaults to. These are absolute pressures not boost so, Set anything under 1BAR @ 13.5AFR target, 1-1.3 BAR @ 12.4 AFR, and 1.4+ @ 11.8 AFR. Set authority for the auto tuner to be +15% / -5%. NEVER accept trims, just let it do it’s thing. This is after it’s been tuned on a dyno only!!
Use the multifunction output for a shift light.
If you do above, you’ll have a self correcting setup that will adapt to an extremely wide range of conditions.
Most people don’t realize just how advanced the PC-V really is, using for just a fuel trim device like 90% of people do is kind of a waste, because Dynojet could make a product 1/2 the cost to do only fuel trims (sadly they don’t).
If the above is over your head, play with the software to see what the different options do and read read read, going into tuning a boosted vehicle without requisite knowledge WILL end up with a broken motor.
