warp9.9
Pocałuj mnie w dupę
@Doc Roc your post above about the could very well be the vibration culprit with one axis stuff it could force a wobble. Sorry but not sorry the bvb earing weren't bad but atleast you fixed one that was installed by a train triumph technician production line monkey with no QA. Afterwards. While your at it check the torque on the output shaft nut. I know a captain in ohio that had shifting problems in as nd out of first gear. His nut backed off a few threads allow the shaft to float a d to and fro from the torque genarated by the helix angle on the helical gears. Two gear amplifying the torque for movement. The movement allowed one of the gear shims to drop down and block the dogs from fitting in the pockets. Youll probably have to put it in gear to check the torque.My bad 35mm, when I got it out. Very strange no one could tell me that before hand!!!
