IMDave
So, tried to start my bike up this morning to go to work. the Bike has been acting weird and It was in the dealer yesterday, and they said it was fine and no error codes. Hoping that you guys can help figure it out.
Note: it's none of the stupid stuff we've all done before (kill switch, in gear, kickstand down)
Issue: Initial power cycle doesn't happen, so start button does nothing
Symptoms:
With ignition key to on:
Fuel pump does not spin up / prime
Limited instrument lights
- neutral light out, high beam works
- yellow engine light out, oil light on
- gas gauge inop
- starter switch doesn't engage starter / press it, nothing happens
- That lack of a power-up cycle seems to be the issue. Like when you leave the kill switch engaged, nothing happens when you turn the key.
Previous 'acting weird' stuff
- engine light on intermittently
- significant (10 sec) delay between turning key and electronic power up sound
- gas gauge going to zero, then returning to normal
- speedo went out yesterday while driving, for about 5 min, then worked again
Any help appreciated!
Update: moving the handlebars, flipping the kill switch, etc. = no change. checked the fuses/relays I could reach, they seem seated correctly. Having the bike hauled to the shop ($115 for an 8 miles drive, sheesh), hoping they can figure it out
Symptoms:
- gas gauge inop
