Idaho Red Rocket 3
- Joined
- Nov 22, 2008
- Messages
- 6,205
- Location
- Nampa, Idaho USA
- Ride
- 2006 RIII Standard Bagger w/Fairing
Dobeck's AFR Plus modifies the signal to the injectors for better fuel delivery. Increased power, fuel economy and smoother. It also monitors in real time your AFR. YOU set the afr you want in 3 zones. YES it is what you are looking for. Call Dillon at Dobeck and tell him Bill in Nampa sent you.
UPDATE: 4/15/2024 Just want to let everybody know Dobeck does not offer this anymore for the Rockets. There was an ECU change Triumph made somewhere in early 2010s that cause a problem with the AFR Plus that would not allow it work correctly anymore. The best thing to do is to find a good dyno tuner that can adjust your ECU using TuneECU.
