Tune ECU Driver for Window 10 Lonelec cable
Hi all the story continues.. Yes i suspect the cable is a fault. Spoke to Gary at triumph performance parts and he is sending me a new cable to try. I hope this does the trick. Will let you know what happens!!!!!
Hi all before i start playing with the new cable that arrived on Friday i just want to make sure i have everything covered and set up correctly. Can someone out there give me the correct driver number that i should be using i cureently have 2.12.26.0. Is this correct.
Finally I've had success and connected to Tune ECU after getting a replacement Lanelec OBD II Cable. Seems the new one supplied was faulty!!!!! . After checking and double checking the installation correct drivers com port etc IVE HAD A CONNECTION. Downloaded the map to keep a copy on my windows10 laptop. If this helps anyone out there having connection problems it is really important that you find the correct FTDI drivers, is your system is 32 bit or 64bit????. Windows 10 is 64 bit , Window 7 is 32 bit . Make sure the program and the cable, com ports are all talking to each other. Now that im connected looking forward to getting some new maps to try. Any one out there who could email me a map for a 2012 rocket roadster with tors and ramair. My problem currently is the plugs are getting fowled when doing short trips around town. Dam traffic lights dont help. Of course i wont a go hard map love the power the Rocket..
