Tune ECU Driver for Window 10 Lonelec cable
Thanks for the reply. Windows says the device is working properly, and the driver is up to date . Still cant get any action out of the cable. The computer wont recognize the usb when connecting. Have checked the com5 port. Ant other ideas would be appreciated.
Hi Tony, this is feeling very familiar and exactly what mine was doing, says the driver is up to date but it will be the incorrect one.
If you have a laptop try dragging that into the garage and setting it up, don't think it will be the cable. This will prove the cable. I'm pretty sure its the software in the tablet.
One thing I found was to watch the Tune ECU closely on startup bottom RH corner there is a flashing square box, goes red, then yellow finally green if you connect. If it just flickers Red its not talking at all.
Okay well im going mad, see i have reinstalled the software, download the driver, downloaded the map, connected the cable and still i get the same result, ECU Not RESPONDING. Well lets try a new approach, downloaded the android version from playstore use my new cables and still get the same result. ECU NOT RESONDING. I know its not a driver issue as you dont have to download drivers in the android version. What the hell is going on. i never had this problem when dropping maps into my Suzuki M109. Must be time to buy a power commander and have a hassle free life. Any help very much appreciate. iF i had hair i would be pull it all out. Very Frustrating.
Power Commander wont let you alter rev limits or top speed limit...you need tuneecu to do that.
I agree with you, all i want to do is connect to the dam ecu, its very fustrating going back over the reinstall checking drivers, using the android version and still getting the same results. i am using widows ten on my laptop, does anyone out there have a different suggestion regarding the cable drivers to use????. I also get the same result when using windows seven. Is there any computer wizard that can point me in the wright direction to get this issue solved. Tony
There will be someone Tony....might not be online right now...im interested also...good luck!
I just did this a few days ago but I bought a cheap cable on ebay and it connected to TuneECU and the bike (although I have not tried a tune yet)
Here is the link for the driver they gave me "LINK"
But first I would try this with the driver you have.
Make sure to go into device manager when your cable is plugged in to your computer and make sure there is not a yellow exclamation next to the USB device or the Ports, if there is right click it and point it to the file you saved the driver in.
Then go into Printers and Devices find your cable, right click and choose properties, then advanced and set the port number (my instructions say port 1)
Then open TuneECU and click options, mouse over interface then serial and make sure its set to the port you selected, when you mouse over USB it should show your cable number.
Good luck
I have tried all options now getting so fustrated with this???/ My thoughts are that the driver is not correct or i have a doggy cable. Can anyone out there give me the driver for the install. i am using windows 10. i have been downloading drivers from D2xxdriver downloads. I have checked the com ports etc. Ant help much appreciated. Tony
