Looks like your coming right along Patrick ! I removed my radiator. You should pull the shrouds, my bet is the hoses are holding things up. I think the radiator will have to come out. The oil filter has to come off if it's not already. It will run into the front tire. That will give you an idea of just how far down it has to swing. I also unbolted my throttle bodies and lifted them up and zip tied them to the frame. You shouldn't have to unhook any wires, cables or hoses. Also the ground cable from the battery bolts on the back of the engine near the starter. That has to come off also.
