best $209 investment possible !
today I used the tools sent to me and removed the swing arm that was a chore had to use a lever three feet long!
and I had the most difficult time removing the little bolt holding the rear hydraulic line on the swing arm the one wwway up where you cannot reach
must be some british engineering brilliance , I will replace that with a plastic tie wrap.
did some pictures showind what the thing looks witho swing arm the little side connection are - one- headlight switch and below trickle charger plugin and since the starter is now quite easy to reach I went and bought the upgraded toyota starter model 17610 looks a wee bit longer than factory but apparently will fit just right according to some earlier posts ..no more flat spots when trying to start beside the old one is 8 years old.
