...hey Mike...
Thunderbike Nelson for bars...K&N's you can install yourself...watch and follow the ramair install video on youtube..I watched this video all the way thru...got the tools ready, put the laptop on a stool beside the bike and started pulling things to bits. I would play a bit of the video...stop the video and do that bit...go back a tad and run the video again, do that bit...etc...it works a treat.. .
You can cut the bearclaw yourself with a cutting disc in a grinder if your skills allow...if not, go for the 'Ramair'..just as good and no need to cut the bearclaw away.
You dont need a PCV but it makes tuning a lot easier....Honda Country in Ashburton are the Dyno Jet guys and Brendan and Andrew know their stuff...
Led's, i got mine from JP Cycles online https://
www.jpcycles.com/...great selection and service. Installation is easy once you have a plan in mind, you will need to change the 3 pin relay plug which is on the right side of the bike under the right panel. I'm sure its the only 3 pin relay there. This needs to be done to correct the flasher speed on the indicators once led's are installed.You can get this online also. Make sure you get this one.
You should be able to access bolts and nuts easy enuff...if you cant get them local then give Blacks Fasteners in ChCh a buzz..i'm sure you have them in Blenheim too..
Blacks Fasteners supply a superior quality fasteners and tools, including Fischer fixings, supported by an experienced sales and service team to builders, engineers, trades and customers throughout New Zealand.
Cheers Tal.
