Are you running the optional baffles in there cos if you are ..... Rip em out and she won't be so quiet and you will let the power out as well
My baffles are still new in the bag never used by first owner or me
:eek: Ehhh! what baffles Hans ? Systen was bolted on complete..
Where are they located if they are fitted ?
I wonder how the dent in the one happened in the curved area, I don't remember seeing that on mine but I will be checking when I get home. Yes and I bet the is a couple snipers watching them.
Could be mine does to I just have not ran them in years. They are polished up and wrapped in plastic to go to Canada.
:eek: You sending them for a holiday ??
Clutch tool arrived today from Dennis Kirk $14 each got 2 and some H- bar risers :)
at the out let end there is a hole in the back and it should look like this (left picture)
if you see one of the these (right picture) in there take an ellen key and remove the sucker:D
They will not be as hard or raspy as the TORs but still Loud just a much deeper note
That dent is also present in the Standard mufflers but not so pronounced as they are a smaller ODpipe leadering into the muffler I think you will find it is the top Righthand muffler and there purely for clearance
Oh and by the Way It is still siting on $100, good luck nolton
Thanks Hans.. just had a good look the holes for the screw are there but nothing fitted.
Further down the tube I can see a sleeve with what lookes like small teeth of maybe holes and I can feel a thin edge it is about 20cm long but it would be difficult to pull out with some damage I think.
Does your have this or is the tube smooth ?
Ill maybe keep the TORs :D
