The current draw from the new horn would be the same so I do not see that it would matter.
I have not looked at the wiring on the Rocket. Is there a relay on the horn? If not you should add a relay and a fuse and draw the power straight from the battery. Use the existing circuit to control the relay.
Billy, i'm not familar with the wiring diagram of the R3 either, so chasing wiring isn't for me. i'm planning on just connecting to the two wires that already connect to the current horn.
if i include an in-line fuse what wattage would you use?
You are essentially doubling the load (at least) by adding another load (Extra horn) and really should be done with a RELAY to ensure enough current is delivered to the two horns giving maximum performance to both.
Mittzy, what i think i hear you saying is that my plan of just adding it into the current circuit either in parallel or in series won't work, correct? perhaps i'll get my local motorcycle shop to install it then.
May very well work - But for how long? as the horns will be sharing the available current that the wiring is able to provide - if the horns are receiving enough voltage but not enough current this could adversely effect the life of the horns and or stress to circuitry of the bike.
Keeping the stock horn back in 2005 when I bought my first Rocket I thought that something was wrong with the horn i replaced it within the first week as I was to embarrassed to use it.
@Mittzy is absolutely correct, you do need a relay. The factory horn draws about 3 amps and the factory switch is just barely able to handle that.
You could trigger the relay and the OEM horn at the same time. The OEM horn switch is switching the negative not the positive wire. So keep that in mind when installing the relay.
