HansO
Not Taking Life Too Seriously
- Joined
- Apr 4, 2010
- Messages
- 13,447
- Location
- Batemans Bay, NSW, Aus
- Ride
- 08 Rocket III R.I.P now TEX Triumph Explorer
All Rocket Motors are the same and I have and can run any tune from any model (including Tourings) in others but they have to be transposed over to the correct Base Map for the year model of the bike, the only thing we can't change is the Base Map it has settings and parameters that Triumph set in the revised ECU's for the different year models, eg a 2010 - 2012 plus some of the early 2013 model run a map which can not be run in the later 2013 onwards map.
As for the early pre Roadster models 2004 to 2009 can all be run on the updated 20228 map, there are probably still a lot of guys running the 20050 map which was fine except sooner or later it will start to cause the engine to cut out when you pull the clutch in which can be very annoying while having fun in the twisties as you can get momentary rear wheel lock ups as you release clutch .. believe me ......I know
Cheers
Hans
Cheers
Hans
