Bedifferent
Old man on a bike
I don't have the Ramair yet so I haven't had a good look at it. Since their is a hole between the 2nd and 3rd throttle bodies for the O2 temp sensor to set in, why can't you put a hole in the Ramair housing between the 1st and 2nd throttle bodies. If you then made a plug for the filter box were the center duct work use to enter, put a hose fitting in that and then run a hose from that to the new hole you put in the Ramair housing. I would use rubber grommets around my hose fitting points and maybe even consider a cover over the top of the airbox. Wouldn't that scavage gases from the old airbox, eliminate the breather filter, create a little negative pressure and make things all good? That was kind of my plan...any thoughts on that guys?
