JamiePT
.060 Over
I went for a ride yesterday with friends from El Paso. We rode out To Cornoudas Texas on to Guadalupe Peak, out to Van Horn and back.
I am really loving my Rocket. I plan on changing both the oil and rear drive fluid at 5 K miles. I know that the oil is not due to be changed for 10,000 miles and the rear drive fluid is some ridiculous interval like 20,000 but I figure it's cheap enough and it's easy to do.
I just hit 4600 miles and figured in oil change was about due. The old oil didn't look bad, but I figure it's good to get rid of it since the previous owner only put 1400 miles on the bike into an a half years. I'm not a big fan of engine fluids when they just sit and gather condensation.
I pulled each drain plug on the bike was nice and hot. Then I put a large drain pan underneath all three and where the oil filter was and used some compressed air to blow out whatever was left. I had the bike proped level as well.
I installed one of those reusable oil filters from PC racing as well. I really like the heat sink feature on the outside of it the dumps more heat away from the engine. I also replaced one of the drain plugs with a magnetic drain plug.
At 10,000 miles I plan on changing the oil and drive fluid again.
However I will also be bringing the bike into a shop in Arizona where I'll be getting my power commander five and Ramm Air installed, new tires, getting the valves adjusted throttle bodies balanced and all the other maintenance that I'm not capable of doing myself.
I'll post an actual picture of the magnetic drain plug and the reusable oil filter screen next time I change the oil to let everyone see what's on it.
