I did both mods at the same time but Bob chose the APE tensioner so only a couple of the larger shoes were made. Of course your shoe can be altered as its just enlarging the oval plunger hole. If I remember right the OEM plunger was about .075" larger diameter then the APE. As for the tensioner mod its really pretty simple even Fred modified his. Myself If I have another rocket with the auto tensioner it will be modified even if its stock just for safety.
so then modifiaction is just with the center nut so it can be done on any bike without losing the timing as
YOU WILL NOT BE TURNING THE ENGINE OVER WHILE THE CENTER NUT IS OUT !!!!!!
below is a couple pictures first one in red is the unmodified OEM Auto tensioner blue is it modified
below in red is the modified tensioner assembled
Basically You remove the dowel pin that aligns the tension spring. Drill and tap the center nut and replace the dowel pin with a 1/4x20 UNC stainless stud.
Now adjusting it. after installing the center nut with the new stud and spring (don't forget the copper washer) You run the stud down to the bottom of the plunger and back it off 1/2 turn. this is not use to force adjustment it is merely there to stop the tensioner from releasing allowing slop in the chain and your timing to jump. Once it is in the right location you lock it with the double nut ( the Acorn nut is for dressing things up a bit I went with a longer stud and a regular nut then ended up finishing it off with the Acorn nut for looks).
