alpental
Turbocharged
You might want to pull the spark plugs and see if there's any fouling. If it's running rich, your plugs will look black and sooty. Remember, there are 2 per cylinder. If you already have a Ramair or triple air filters installed, pulling the spark plugs will be pretty easy.The oil is pretty black and has a strong gas odor. I am wondering if my fuel air mix is off or I have an injector issue.
After this 5K running Castrol RS 4T 10/40 and a K and N 204C-I am switching to a 22u reusable metal filter that actual filters the oil rather than pushing it through the bypass valve.
Any thoughts on causes for excess petrol smell coming from the oil (Amsoil) or is that to be expected with 8K miles on the oil?
Might want to look into the micron filtration rating for your metal filter vs what Triumph requires (can be difficult to find these values), and make sure that getting rid of the oil filter pressure bypass valve is a good idea. Don't want to blow a gasket, literally then figuratively!
