Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,832
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
OK guys, I need a little help here. I have finished installing the pipes and triple k&n's and have applied the tune: Power-Tripp Jardine 3xK&NRU-2780a.hex from the TuneECU website.
The problem is that I can start the engine but only by giving it a fair bit of throttle and the holding the throttle above 2500rpm. If I let it drop below that, it will cut out and fart back through the intake as it does so. I therefore cannot reset adaptives because it won't start and idle. Even when running it is slow to pick up when applying more throttle.
I have check the TPS readings and they are 6.0 and 7.0 which I believe shouldn't be the problem. I have no error codes and have tried all the diagnostic tests and all seem ok.
Any ideas please.
Your bike sounded like it was running halfway decent in your sound clip. Were the K&N's on it then ? If not, I would raise the tank and look for sensors being unplugged and vacuum lines being kinked or unplugged. If they were on and all you have done is changed the tune, I would reload my original tune and see if that's the problem. Maybe the Power-Tripp tune got knackerd somehow ?
