RocketEd
My 2010 Roadster started right up and ran great while I closed the garage. Ran fine until I pulled out onto the road, then it started misfiring and wouldn't take throttle. Engine light came on, turn signals either wouldn't work at all or they flashed really quickly.
Got it home and turned it off. When I turned the key back on everything was dead, no lights, no fuel pump prime or anything.
The main 30amp fuse was melted, not cleanly blown.
TuneEcu cause code (I think) said EMS main relay circuit. Really should have written it down before clearing codes.
Replaced the fuse, swapped fan relay for EMS relay, cleared codes, starts and runs fine, everything works, engine light didn't come back on, but it still seems to be putting a lot of heat through the main fuse.
No heat, or evidence of heat in the EMS relay itself and it checks out with an ohm meter the same as the cooling fan relay.
Turning the handlebars lock to lock had no effect. Eastern Beaver headlight relay system installed years ago.
Any advice from the collective other than to start checking over all the wiring?
TIA
TIA
