Lost back breaks
Discussion in 'Common Issues' started by Boog, Mar 11, 2019.
  1. Boog
    Boog Traveling Story Teller
    Country:
    United States
    4,862
    Featured Threads:
    53
    7,899
    823
    Dumfries, Virginia
    Ride:
    2014 R3T, TORs,
    Hey guys, I'm on the road at Daytona bike week and lost the back brakes yesterday. I figured I just needed to replace the pads so I did today. After the fourth pump, I can feel some braking action but not full power and I cannot get the ABS to kick in at all. What next?
  2. breeze
    breeze Living Legend
    Country:
    United States
    2,444
    Featured Threads:
    6
    2,920
    823
    bloomfield n.m.
    Ride:
    07 classic/01legend/72 bonne
    you got an air bubble in system?bad master cylinder?brakes are nice but overrated be careful
    BigNorm, Nat67, Boog and 1 other person like this.
  3. Dawg68
    Dawg68 Nitrous
    Country:
    Canada
    1,307
    Featured Threads:
    43
    951
    223
    Chilliwack B.C.
    Ride:
    2014 R3R / 2017 R3T
    I’d bleed them if you have the ability to get somewhere to pick up some fluid.. probably the easiest way to start
    Boog likes this.
  4. phar2slo
    phar2slo Nitrous
    Country:
    New Zealand
    1,116
    Featured Threads:
    12
    1,445
    223
    Christchurch
    Ride:
    2006 classic
    I usually only use the front brake at the best of times.
    But always use both when stopping in a hurry. So at least twice a week when a cager pulls out in front of me.:thumbsup::thumbsup:
  5. Rick Morris
    Rick Morris "Have you seen Junior's grades?"
    Country:
    United States
    1,468
    Featured Threads:
    12
    Media:
    19
    1,529
    223
    Cape Cod, MA
    Ride:
    2011 Rocket III Roadster
    Everytime I take the bike out after it sits for a while I have zero rear brakes. So I pump the heck out of them before I pull out of the garage. I have replaced the pads and bleed the brakes. My 2000 Valkyrie did this once in a while. But no other bike I have ever owned has done this.
    Nat67 and Boog like this.
  6. scot in exile
    scot in exile Living Legend
    Country:
    United States
    7,557
    Featured Threads:
    173
    8,743
    823
    Fort walton Beach FL, Glenrothes Fife
    Ride:
    2005std, 2011 Carp Roadster, 2001 Tri Adventurer,
    Air in the system, check for leaks also new pads might be in order, as for braking
    Front And Rear Together, if you only use one brake just remove the other one altogether after all less weight equals more speed
    always remember to F-A-R-T
    TURBO200R4, sonny, phar2slo and 2 others like this.
  7. Jag
    Jag Living Legend
    Country:
    United States
    2,883
    Featured Threads:
    27
    3,684
    823
    Cape May Co. NJ
    Ride:
    2013 R3T
    Hey boog, good to see your still around!!
    With that said I have a theory about the rear brakes. The close proximity of the master cylinder, and the brake line to the exhaust causes the brake fluid to boil(especially on a long trip) and then its crap. Also if the pads(or pistons) hang up a bit that will cause more heat!
    The brake dust builds up on the guides for the pads the pins and around the pistons. It’s a good practice when changing the pads to remove the caliper and clean every thing and use a little high temp brake grease on those pins.
    Good luck brother, hope you get er sorted!!
    BigNorm, Nat67, Joesmoe and 3 others like this.
  8. John Ward
    John Ward .060 Over
    Country:
    United Kingdom
    104
    Featured Threads:
    2
    92
    38
    York UK
    Ride:
    Rocket 3 Classic 2008
    Wow I have never had zero brakes even when my bikes have been laid up for the winter.... I suggest you strip and rebuild them if that's the case as something must be wrong....
    Nat67, Boog and Rick Morris like this.
  9. sonny
    sonny Living Legend
    5,449
    Featured Threads:
    103
    8,978
    823
    Henryetta Oklahoma
    Ride:
    rocket three x
    I had issues with the back brake for awhile. Fade out overtime. Then we would bleed the brake and a lot of air bubbles. Checked entire system no leaks. Everything was clean and function properly. Out of total frustration and lack of trouble shooting the problem went ahead and replaced the bleeder. o_Oo_Oo_Oo_Oo_O No sign of leakage but glad i did. Problem solved.
    BigNorm, Boog, Rick Morris and 3 others like this.
  10. cootertwo
    cootertwo Nitrous
    Country:
    United States
    1,346
    Featured Threads:
    25
    Media:
    4
    2,081
    223
    Labelle Florida USA
    Ride:
    2013, & 2 05's R3R, 2006, 2004 Harley's, 2004 Kaw
    My 2013 has a low rear brake pedal. I've bled it, adjusted the linkage, but still low. Almost have to stand up on it, to get the anti-lock to engage. My 2 05's have no problem, but they ain't anti-lock either ????
    BigNorm, Boog and Rick Morris like this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
