Little help with outlaw pipes please
Huffa
Oxfordshire
Rocket roadster
Hi all
I've just installed a set of Dave platt outlaw exhausts and k&n filter on a 14 plate rocket roadster as I'm sure a lot of people have but I'm getting loads of black smoke which I guess is from over fueling.
Got an ecu cable on the way so I was wondering if anyone can point me in the direction of a map that can help. Or any other suggestions would be much appreciated. They sound great by the way.
Cheers
Nat67
Rockgoblin
Dartmoor England
Rocket 3 2010 roadster
Hey Huffa ,
It's strange you should be running rich with the combo you have ? By all rights you should be lean , way lean ! What pipe and filter was on the bike before and how did she run ? If you went from standard pipes and filter then I would suggest you look over what you have done , make sure everything is connected back up as it should be . Where have you mounted your AIT sensor ?
Nat67
Rockgoblin
Dartmoor England
Hey Huffa ,
Oh and welcome from sunny Dartmoor !
Huffa
Thread starter
Oxfordshire
Rocket roadster
Calling @Nat67
Welcome - but update your profile so we know where in the UK you're at.
Hey Huffa ,
Hi Nat67
I had the triumph aftermarket pipes on before with their map but the insides rotted away. Everything else standard. Though it ran like **** the last time out there wasn't any black smoke until I changed pipes
Huffa
Thread starter
Oxfordshire
Rocket roadster
Hi Nat67
Haven't done anything with the sensor I'm new to all these intelligent engines
Huffa
Thread starter
Oxfordshire
Rocket roadster
Very strange as all you have put on is a slip on exhaust and a underseatk&N (as you said k&n filter) hope it is something simple
Hi Scot
Yep just an underseat k&n nothing major. It has to happen now with calne bike show at the weekend
Similar threads
AdBlock Detected
I've Disabled AdBlock
