A WHITE LED is NOT the same as a broad-spectrum incandescent 'white' light - behind a Red Filter Lens, you should really use a RED LED, otherwise it will be cutting off significant amount of light.
The Red Filter (because that's what it is - it only lets red light wavelength through) is going to transmit majority of the generated light from a narrow spectrum red LED compared to the loss from an incandescent but even more from a white LED (albeit the LED probably generates much more lumens to begin with)
The general 'rule' is always use same colour LED as the LENs filter is going behind.
i.e. Yellow LEDs for Turns and RED LEDs for tail/stop
Of course with a coloured LED you can also use a clear lens.
