scot in exile
scot in exile,
Have you been under the tank recently and perhaps dislodged the vacuum hose that connects to the MAP sensor?
Another possibility is that the MAP sensor itself is dirty, blocked or damaged. You can by MAP sensor aerosol cleaner at AutoZone or O'Reilly's so it might be worth a punt. It takes only a tiny piece of debris to make the sensor FUBAR.
Regards,
Mark Dunn
Appreciate the input Mark but I can guarantee all the vac lines are fine in fact I inspected them so closely I could tell you the serial numbers on each line.
Would that cleaner stuff just be the same as the canned air for cleaning keyboards?
