Oil sweating next to kick stand??
Radek
Standard Bore
Rocket III Roadster
Hi Rocket’s owners.
I have R3R from 2013 and recently I noticed a kind of oil sweating around the kick stand and a few screws nearby. It is not dropping to the floor it is just on the area I described. It appears despite of riding or sitting in the garage-strange. Have anyone experienced such a phenomena? If so what is the fixing procedure? I attach a couple of pictures.
Here you go...
Thanks Journeyman, however this issue description is for latest gen of Rocket, I have 2013 and there is not such starter cover and the engine was redesigned. I need to disassemble the kick stand and look around.
prbaqbly the oil tank orings.
mine were leaking spots but now just seeping.
pain in the ass to change because you have to pull the throttle bodies.
My bad, Radek. I had a 2011 Roadster and of course the design is different from the 2.5s. As someone else said the valve cover gasket may be your culprit. Unfortunately, I’ve been away from that bike too long to offer any other suggestions. Check that first and, if not, others will be along with good ideas
Witam właścicieli Rocket'a.
Mam R3R z 2013 roku i ostatnio odłączono coś w rodzaju oleju kapiącego wokół stopki bocznej i kilka śrub w pobliżu. Nie kapie na kabel, tylko na miejscu, które opisałeś. Pojawia się od jazdy lub postoju w bagażu – przypadkowym. Czy ktoś spotkał się z możliwością przeniesienia? Jeśli tak, jaka jest procedura naprawy? Załączam kilka zdjęć.
To jest nieszczelność nieszczelności
