DEcosse
If it's no Scottish it's CRAP!
i will recheck all the hoses, I changed the plugs this morning and it started right up and was fine for about 10miles now it will not even try to idle(could the plugs foul up so quickly?)
OK - that is encouraging news - definitely sounds like the plugs are fouling and changing them gives some momentary relief
But that was before you reset adaptions, right? (& when the adaptions were subsequently reset, it was with already fouled plugs I presume?)
If you can clean them and get it to idle, check those MAP sensor readings
Again, it's all 'theory' at this point, but assuming no vac leaks, it kinda 'fits' that you started out with clean plugs and fresh mapping situation; then it progressively trims to point where you have overly rich condition and it fouls the plugs; you change the plugs and it starts OK but then quickly falls off again - if fueling had already been 'trimmed' to that seriously rich condition, then plugs would quickly foul again. If adaptions were reset, it may not have immediate desired effect because plugs already seriously fouled.
Same mechanism could prevail, even if OEM was not trimming and plugs were just fouling off a very poor fueling condition from the outset. Although you might expect that it would take longer with fresh plugs again unless the fueling was worse than when you first started into this (unless it HAD already been 'trimmed')
I'm not 100% sure whether just unchecking the box for O2 sensors actually disables closed loop - I've seen mixed opinions on this (in that it only disables the error if disconnected, but not the actual operation of the sensor & its effect in closed loop)
Two things will prevent it being in closed loop for sure - if the A/F table is set to less than 14.5 in any of the cells; if the O2 sensor is physically disconnected (at which point you need the box unchecked to prevent an MIL error)
On my own bike, OEM sensor is completely removed and I actually have a wideband O2 connected with no closed loop feedback to the ECU.
For anyone with a tuned bike, a wideband sensor is really nice piece of gear to have.
