.... Note that pc maps are piggy-back & developed with respect to a given OEM map so whichever oem map it relates to is what should be installed (this should be a 'std' factory map typically but you need to ask specific question)
So now I am on desktop rather than phone, I can see the PC map - in its notes it says 'Touring Model' so you (reasonably) presume that map was developed with regard to a Touring base map
- that is one big problem with swapping PC maps between bikes - you don't have a single net result, it is a combination of OEM map in the ECU modified by the PC map
So whatever the OEM map is, it will still play a significant part in the final result and it SHOULD be the one upon which the PC map was first developed.
With custom PC maps you can never be sure what that ECU map was - whether it was already modified from OEM before the PC was even applied.
But again - what exactly has changed? Even assuming a less-than-ideal combination mapping condition, why has it deteriorated?
My guess was that the OEM ECU was 'trimming' to overcome  the changes input by the PC map;
but that should have been resolved by resetting the adaptions;
however if the performance was dropping off as the plugs became progressively more fouled that could also be a factor.
It could be a combo of both
I sound like broken record, but unless you can get it to at least idle, (wher eyou can get MAP readings) go through the vacuum system meticulously and be sure that you have no open ports, disconnected or ruptured hoses.
