CCjon
All who wander... seeking fresh cup of coffee
- Joined
- Aug 24, 2017
- Messages
- 171
- Location
- Cypress, Texas
- Ride
- 2018 Honda Goldwing / Hannigan sidecar
Need some advice from someone with more Rocket electrical knowledge than I.
This is a 2011 Roadster, running an auto battery and sidecar. Installed the group buy heavy duty battery cables and Power Commander V, turned on the ignition, no sweep, nothing on the gauges. Headlights high and low, taillights, brake lights, all work. Left turn signal works but not the right. Had no problem sweeping and starting before I did the install. Am sure I knocked a wire loose, but which one. Wiggled and jiggled all the connections with the key on, no sweep.
Removed the PCV, problem remains. Checked all the fuses in the fuse box, all ok.
Tested for continuity in ignition switch, have it between the white wire and the brown wire terminals only. Is that normal?
The plastic sheath on the ignition wires was brittle and breaking. So removed it and put on a new sheath. Underneath the yellow wire had a gap cut out of it. It looks like it might be for the alarm system which This bike does not have. Maybe cut at the factory?
After reconnecting everything under the tank, there are three plugs unused, is this correct?
Where to start looking next? Any suggestions or help would be greatly appreciated.
Jon in Texas
Jon in Texas
