Easy Off Saddlebags
Great info as always. I just went through some old posts and sounds like the Easy Bracket is preferred over the Ghost brackets because the Easy Bracket is actually made to fit each separate model of bike whereas the Ghost bracket is adjustable. You'd think adjustable is better but apparently said adjustability has caused some Captains difficulty in terms of fit and possible bag shake.
I also watched the Easy Bracket how to video and they instruct users to drill 4 holes straight into the saddle bag to install the Easy Bracket. On the other hand, I've seen a picture of one of the Captains who has installed the Easy Bracket onto the OEM saddlebag bracket and then attached both brackets to the bike. It seems that employing 2 brackets (OEM bracket + Easy Bracket) between the saddlebag and the bike would create a significant gap. Anyone have experience with this set up? Thanks.
I just mounted mine straight to the bag had to trim the bracket a little at front lower corner but no problems and no bag shake
Here is something from the .com site
Just finished the conversion. Took about an hour and now I only need to take out four bolts to remove the saddlebags instead of fourteen. In order to make this switch, you'll need the following tools in addition to the ones you normally need to remove the bags: 25/64" drill bit, 15/32" drill bit, 5/8" or 11/16" drill bit. Here's the process:
1. Remove the saddlebags as you would normally do. Remove the frames from the bike.
2. With the frames off the bike, reinstall the bags onto the frames. You don't need to replace all five screws - two or three will suffice.
3. Using the bolt holes on the frame as a guide, drill through the frame into the bag. Go slowly and use very little pressure. The inside of the bag has a plastic liner that will crack if you go too fast or use too much pressure (found out the hard way.)
4. Remove the bag from the frame.
5. Enlarge the holes you just drilled using the 5/8" or 11/16" drill. If you have a drill stand, use it and back-up the holes with a piece of wood. This will help avoid cracking the plastic.
6. Reinstall the bags as normal, except now the two large bolts will pass through the back of the saddle bag, so you won't have to remove it from the frame.
7. Cut a piece of inner tube or neoprene large enough to cover both holes, place some velcro around the perimeter and install inside the saddle bag covering the holes you just drilled.
This is a pretty easy project and should make it much simpler to remove the saddle bags in the future.
Clever ........ ;)
That mod is definitely the best bang for your buck!
But I think the Easy Brackets would still make adding and removing saddlebags more convenient and thus, for me, more likely I will actually use them. So I ordered the Easy Brackets over the Ghost Brackets based on past reviews regarding fit and customer service experiences. Now I just have to decide whether to drill holes in those beautiful bags or attach directly to the OEM saddlebag bracket.
I think I will also get Flip's saddlebag stiffeners and get the Triumph inner bags for even more added convenience.
Thanks again to everyone for the input as always!
