OK. Just went back out and did that. Green light, ECU drop down had a "Reset Adaption" which I pushed. Confirm message as well.
Bike did the usual start up noises like it does when the key is first turned on and then all finished.
Disconnect and started up.
Same problem. Idles at about 500RPM when cold. Stalls if I take my hand off the throttle.
I'm thinkin it's most likely the stepper motor.
Is the O2 sensor the one in the exhaust???
If so, it's not there any more with the K&N set up. There's a bung in the exhaust and 4 little rubber gromets in the electrical plug beside the ECU.
I can't see how the ECU could be reading any info from the sensor if it's not there, unless it's trying to compensate for the fact that it's not getting info at all. Not sure
Should I have ticked a box to say that the sensor has been deleted???? Not sure where I should have done that, or was it already done in the existing program????
