Reset Adaptations question
sleeves
Nitrous
Backblocks, Waikato, New Zealand
05 R3 Std
Ok before doing the reset adaption did you check the 7.0mm nut? Over time, and adjustment, they end up wound in too much and the stepper can move one way only. Easy to check by looking this. I back the 7.0mm nut off, do reset adaption, then set tps and stepper. Mostly works.
Jeff06098
.040 Over
Thread starter
Winsted, CT
2005 Triumph Rocket
I can give that a try next time. TPS and ISCV are both perfectly within spec.
sleeves
Nitrous
05 R3 Std
Correct they (the values) can be in spec but the mechanical adjustment on the arm set by the nut can be incorrect. When the system tries to adjust it cannot move in one direction. This can cause hunting and poor idle. This is why you back the 7mm nut off BEFORE doing the adaption reset. THEN do the TPS and ISCV. The 7mm nut will need adjustment just wont be at end of its adjustment. Have seen this numerous times is all.
