Question about setting the time/date
azmerlin
T Rocker III
Hi,
Yesterday, I was testing some things so disconnected the battery on my R3 2016.
Later, I switched it on and the engine light came on.
I talked to a local dealer today who said that this happens because the date and time were reset due to disconnecting the battery and that I will have to bring it in to reset the date/time.
1. Does this sound correct?
2. Can I do these with the TuneECU app?
Thanks
R-III-R Turbo
Mine is the biggest :)
Ireland
2.5L Stroker Rocket III, Hayabusa
Sounds fishy, if you have TuneECU you can see what fault code is causing the check engine light
azmerlin
Thread starter
T Rocker III
Would like to get the TuneECU, but there seem to be a lot of options, so am trying to learn about it, happy to get recommendations re Android device (I am an Apple user), Dongle (I understand that the R3 does not have OBDII, but on the site they seem to regiments an OBDLink.. so I am a bit confused), will also need an app
R-III-R Turbo
Ireland
That's the cable
If you have a Windows laptop, you can use the (no longer supported or developed) Windows version of TuneECU, i can email you the ZIP if you like.
Otherwise maybe get a cheap Android tablet, and TuneECU app from the Google Play store.
azmerlin
Thread starter
T Rocker III
That's the cable
Thanks, I have a cable and connector I got for my Ducati, I assume it will work here as well, if you could send me the zip, that would be great, thanks, is it an install or just an executable ? my mail is rocket@zirlin.com , thanks
R-III-R Turbo
Ireland
Sent, there are a couple of drivers in there that you need for the cable too. TuneECU is just an executable program
