Old N' Grumpy
- Joined
- Aug 8, 2015
- Messages
- 3,809
- Location
- North Florida in the Deep South
- Ride
- 2014 Triumph R3R & 2005 Harley FatBoy
Old and Grumpy,
I have tried the Rivco floorboards on my '14 Roadster and found that the angle is different (forward leaning) than they were on the older bikes so they didn't work for me. I also tried the Raask moveable footpegs kit, but because of the position of the shifter pivot point you can not use a heel/toe shifter with them. I finally went with the Kurakyn 4351 Premium Floorboards. With some minor adjustments (nothing other than what was designed into the systems) to the shifting lever and brake pedal I was able to get them in the middle hole and allow proper motion for shifter and brake. Now I am working on getting someone who can make or convert my shifter to a heel/toe model and the brake pedal to one more like that on the Touring model (I fear that a heavier brake pedal will require a different return spring also). Unfortunately, the pivot point size of both of those items is different on the roadster than the touring model so direct replacement is not an option.
The search continues. I look forward to what you come up with as well.
Thank you for that.
