Tdrager you are wasting your time and energy some people read to much tech and don't get enought real experence I have seen this argument before and you won't get it through concrete thick skulls the racing argument is as you said an appilcation you also wont see racers using Street tyres at the same lean angles as Slicks in some Lower Classes of racing they use street tryes to reduce the risk for less experienced as to experienced riders
Warp please get real while I have a high respect for your techincal tunning knowledge, but your opinions seem a bit second hand maybe you have been influenced by that other mate of yours Art who also is very good techincal, something you might notice if you want to refer to racing is that different riders use different settings and componds on the same bikes, that doesn't make one better than the other it just illistrates that some load the front up more than others, As for the corner clearance the deformation of the darkside is relative to the tire pressure therefore if the correct pressure (to suit your riding style) is in the tyre preventing it from going on to the sidewall so do maintain a slightly higher profile and increase the clearance before you Grind away your pegs I have been able to use a wider section of the front tyre yes I can get over further (more wear around the sides of the front a mate following on a Honda CBXX 1100 Blackbird commented that he was grinding at the same time and could not believe the angles I was getting) while running a darkeside and have gotten 1000km's more out of this last metz which sort diffuses your therory that it speeds up the front tyre wear. I have just yesterday replaced Metz with a Shinko 757 (new release ) 150/80/17 RADIAL, Shinko used to be known as Yokoama and have good rep. something you might not be aware of is tat the metz is a cross ply the only other Radial is the Cobra which i will try if I am not satisfied with the Shinko. I think the biggest problem is that triumph used crossply tyres.
as for the braking issue I my self have exprenced an unexpected lock up with the Metzler that almost caused a highside and in the dry, it skewed sideways and lifted me out of the saddle but luckily I was able to catch it, upon pulling up and inspecting the surface of the road I found nothing wrong with the surface and a skid mark no more than an inch wide and yes I am an exprenced rider that honed my braking skills on dirt bikes many years ago an advocated balanced braking to the countless numbers of learners I have introduced to riding over the years,. I think you will notice the bike in the crashed bike was a Touring and not the Roadster which now have ABS mmm!!! could it be cause so many Stds and Clasics reported unexpected lock ups, don't be suprised if after few more tourings go down they don't put ABS on them to I wonder why Triumph saw fit to put the ABS on the model with the wider tyre first mmmm!!!
Now can please get back on topic and give honest reviews for those seeking feedback!!
