Custom Pipes are In!
you need to check out tuneecu.. it only costs the cable there are posts on this site.. if you arent running tb or pc3 how the heck are you "running" any tune ?
Desertwolf, you really do need to get that cable for tuneecu i'm guessing about $20 then drop a tune into the 'stock ECU' with either powertripp's 'jardine & 3xk+n's' tune or sam's pred tune
Your running way to lean with the setup you have now, your going to f*ck the engine
Err I have the cable. I've been using tuneecu. The jardines tune hates my bike too lean. The other tune for predators I have is way rich. I mentioned tuneecu in my last post becsuae it's what I have and was pointing out that I'd nOt save any money by buying a pc or tuneboy. Not sure how it read as me trying to run this setup on a stock tune. Miscommunication I guess
how did you get on with leaning off the Pred tune I don't reckon you would need any more than 10% of the F Trim table:cool:
Desert---got a little rise outa my ole geezer pecker from that little throttle bump. !! ha!! sounds good !! maybe travelguy and slaphead can help ya get ya tune figured out. w/o dyno $$. good guys!! lookin fer mo youtube when ya get it fixed !!
Sam---thanks fer pics! did Burns design that 1&2 into 3 combo?
-is there one "bigger" pipe from combo to end? oval?
--is 2nd shield a dummy?
---i see ya didn't provide no photo past combo!! ha!!
is that SS--sam secrets?? ha!
--nice work---as usual!!
not much of a comment on blueing huh !!! ha!
Pig---no work on bike--try 4 yrs!! can't be big rat if ya ain't got "big cheese"!! ha!!
later--john
So I've been trying to get a tune I got from Hanso to work. It was running way rich and I turned it down first 5%, then 7%, and then 10%. No beans. I got the bike to go down the block ONCE, and it cut out anytime I let off the throttle (even leaving the 0% table at 0 while turning the a/f down in all the other columns).
For giggles I tried the Jardines tune on TuneECU. No beans, bike won't start and idle.
Then, I pulled the plugs..
:( I am assuming she cranks over once but won't start and idle because the plugs are FUBAR. By the way, getting just the one out to look was a bugger. I still have to get the front 3 out somehow.
Anyone have any suggestions?
